Prop Replacement - Rebuilt Boat
FBCoach
I rebuilt a runabout and believe the boat is much heavier now. It's a 20' Bombardier Celebrity with a Mercruiser 4.3 LX with Engine number 0K158135 and Drive number 0K068222. My prop is a three blade 14.5 with 19 pitch. My WOT speed is about 33-34 MPH and the boat is slow to plane. Hit a stump today and one of the blades broke off. Any suggestions on what to replace it with? Thanks in advance.
jimmbo
What WOT rpms were you getting with the current prop?
a 20ft boat is a lot for a 4.3
FBCoach
We live on a HP limited water shed. I am the second owner. I believe the previous owner wanted a large boat, but was limited by the motor. May not have been the best decision, but its what we are working with.
jimmbo
You are already at the top of the WOT RPM range. I guess you could drop 2 - 3 of Inches in Pitch, and add another Blade. You will lose Top Speed.
However, before doing that, an Engine Inspection should be done. Compression Test, Check for a good Spark(7/16" gap) on all Cylinders
