Prop replacement spacer question
hoytheld
Got a new prop off eBay, same part number as the one I took off.
not sure if this new one is a pinch different construction on the hub, but when I slide it one, it seems to bottom out before the spline clears the hub, which does not let me slide that brass splined spacer onto the splines. So, can/do I use the spacer even though the splines aren’t engaged? Or, is there another issue I am not seeing?
Ayuh,.....
Ayuh,..... What drive ya got,..??
Ayuh,.... A few hints will help,.....
What year is it,..??
What motor,..??
