Greenhead2012
- May 25, 2012
- 23
I have a mercruiser 3.0 in which I tore down to rebuild water pump, and replaced gimbal bearing and bellows. I did not replace the shift cable but removed it to replace the bellow. I put the drive on than installed the lower unit. When I did the work the drive was placed in forward gear WOT.
Now when I place the throttle in forward I can turn the prop clockwise but there is a click. When in neutral it spins freely in both directions. When in full reverse it spins counterclockwise but with a little more force you are able to turn it clockwise also.
My question is the click normal and is it ok that with some force you can spin the prop clockwise in reverse?
Thank you for any guidance that you guys can offer!
