First I need to make sure that you understand I am not asking how to select a prop for a motor. Its a little more complicated than that. <br /><br />I have a prop, prop shaft, rudder, shaft packing, shaft support (all the underwater running gear) etc. The boat is tunnel drive. I have an engine that I know will definitely provide enough power for the boat/prop combination as it is a larger hp/cubic inch version of the original engine. <br /><br />What I don't have is the original transmission. And I dont know what the original gear ratio was. I have a very good idea on how to measure pitch etc. At least good enough to get the basic pitch and diameter etc.<br /><br />What I can't figure out is how to determine the rpm's to turn the prop. If I know what rpm's to turn the prop at WOT, then it is easy to figure the gear ratio I need. Its got to be simple. With transmissions and gears not being cheap, I just cant go swapping around until I find a combination that works.<br /><br />Is this a case of not being able to see the forest because the trees are in the way? I have racked my brain trying to figure this out.
