Prop selection for Yamaha F115 on 19' Bay Boat
webyrd
I bought a used boat a few years back, have always suspected that I am slightly under-powered or over-propped, but it has been "good enough" under most conditions, gets on plane reasonably well, cruising and top speeds are OK for me. Usage is mostly fishing (2-3 people), occasional family "cruises" (3-5 people), pulled a tube a few times (a little slow to get on plane while towing, but it always got up). Two weekends ago, I took my son and some in-laws (250 and 350lbs - plus gear, cooler, "snack" bag), had some trouble getting and staying on plane (it always planed, just struggled a bit - maybe a lot when the in-laws had to move to the stern because they couldn't handle the ?chop?). Everything was back to normal after we dropped off the two heavy-weights. For the last few weeks I have been doing research on-line, ended up here, ?lurking? (also did some testing / number crunching) - now am pretty sure that I am a bit over-propped, Christmas is coming, and I think it's time for a new prop.
I would like to: get on plane quicker when towing or with heavy load; stay on plane easier at lower speed / RPM's and reduce prop slippage to a more acceptable percentage (just learned about that). If possible, I would like to reduce a slight "slippage" (maybe ventilation?) issue in tight turns on plane and similar "slippage" under choppy conditions (not bad, I can control it by trimming in a bit in both cases). Not overly concerned about getting the absolute highest top speed, but would like to stay close to where I am at now.
Current prop: 3 blade painted aluminum stamped "Solas Myth D 3X13X19R", came with the boat (looked almost new then), now ?1/2" of paint worn off at tips, some small nicks in the tips, no major chips or dings.
Engine: 2006 Yamaha F115TXR outboard, good running condition, recently tuned, recommended WOT 5000-6000 RPM, max HP 115 at 5500 RPM, gear ratio 2.15, mounted directly to transom, anti-ventilation plate is 3" above keel (transom sets back 7? and rises 3? from back of keel), has a Sting-Ray Hydrofoil mounted to the plate (tried removing it once - from memory: doubled my time to plane; increased bow-lift a little; no significant change in speed or RPM - I put it back on), the foil does have a small chip on the rear corner.
Hull: 2007 Cape Craft 19CC Bay (hull is clean but could use polishing), fiberglass (encapsulated wood stringers & transom), 150 max HP, capacity 7 people / 1275 lbs, length 19', beam 7'11", modified V (9? dead-rise), no trim tabs, hull weight listed as 1725 lbs - plus lots of extra weight: 40 gal gas tank; 24v trolling motor plus batteries; additional deep-cycle battery (for lights, Sonar/GPS, VHF, live-well pump when not under power); on-board charger; anchor and standard safety equipment.
Usage: 85% fishing (or going to), 15% cruising/tubing - 25% salt, 50% brackish, 25% fresh - at sea level - generally 2-3, rarely 4+ people.
Current performance with average load - 3 people (?420 lbs), ?30 lbs extra gear/food/drinks, ?8 gallons gas:
WOT @ 5500 RPM - 36 MPH (22% slip) (I rarely run at WOT); fast cruise at 5000 RPM - 33 MPH (21% slip); comfortable cruise - 4500 RPM - 31 MPH (19% slip).
Also did a light load WOT test (just me with ?5 gallons gas) - not much difference, maxed at 5550 RPM - 38 MPH.
Slip numbers seemed high, so I checked tach vs an inductive clip on tach, same ?50RPM from idle to about 3500 (was afraid to go higher without a load on engine).
Went to a local marine dealer (had a few props in stock, not sure how "expert" he is), he advised that going to same size stainless 3-blade prop with exhaust vent holes (he recommended a Turning Point Express) would probably be about the best I could do prop-wise, or lose the hydrofoil and add trim tabs (too expensive for my taste). He said that ideal WOT RPM was 5500 since that is when peak HP is generated. While I agree about going to stainless, as much for durability as for the slight performance boost (actually, most of what I read says an efficiency boost, does this relate to slip? - don't see how?), I'm not sure about his other opinions. After my research, I am considering a Solas Titan HR 4-blade stainless 13x17 (3453-130-17) instead. My reasoning:
Al to SS: +50 RPM plus slightly better all-around performance/efficiency plus better durability;
19 to 17 pitch: +400 RPM plus better hole-shot, plus hopefully reduce overall slippage;
3 to 4 blade: -100 RPM but better hole-shot, stay on plane at lower speed, reduce slippage in turns and chop (and hopefully overall), but will add more drag/lose some speed.
If I got the math and numbers right, at my average load, I think I should end up around 5850 RPM at WOT (still within range, give me a little leeway for light loads) - even at 22% slip, I think I would make around 33-34 MPH. I can live with losing 2-3 MPH that I never really use if I can improve hole-shot. Hopefully I will decrease slip (even improving to 18% slip should give me about the same WOT speed).
Additional questions thought up while researching:
Is cruising for extended periods below 5000 RPM OK or is that considered "lugging" the engine (should I consider dropping to a 15? and watching my RPM?s more carefully - I don?t tend to be a tach watcher, drive more by the way things feel)?
Other than being able to replace just the hub or prop, and the cost, are there any advantages / disadvantages to the two piece hub/prop systems?
If my thinking is out of whack, or if you have other suggestions, please let me know, I'd rather be called ignorant (I admit to being a NOOB at this) than get it wrong. Thanks in advance, sorry this ended up so long.
SkiDad
Re: Prop selection for Yamaha F115 on 19' Bay Boat
Without a doubt I would go to 17 pitch. That will make a world of difference.
dan02gt
webyrd,
I think your pretty dead on with the prop choice although I not sure you'll see a 400RPM gain. The Solas HR Titan 4 in 17 pitch will improve you hole shot and should reduce those terrible slip numbers you have now do to it's cupping and blade geometry.
As long as your propped in the correct RPM range at WOT there is no problem with cruising around at whatever RPM range you want.
You may also want to look into a set of Smart Tabs. They provide many of the benefit of traditional trim tabs at a fraction of the cost, and you could loose that hydrofoil.
Silvertip
For any Yamaha outboard owner facing a decision on "What Prop Do I Need" question, my suggestion is to go to the Yamaha web site and check "Performance Bulletins". Within that portal you can select your boat, engine type (2/4 stroke) and engine HP. Chances are yamaha has tested most popular boats with your engine and they will list every pertinent detail including engine rpm at speed, fuel consumption, time to plane, top speed and rpm and in many cases, even noise level. The prop used in the test will be listed as well. If they don't have a test of your exact boat, pick one that is very close in design, type and weight.
mpsyamaha
Those f115s are known to be pretty gutless as far as getting up on plane is concerned. I wouldnt be scared to turn it to 6000 with a light load, thats how the little 4cyl 4 strokes like to be propped. i agree with the great advice already given, that a 17p prop will perform much better... which one, thats more of a guessing game (try and see!)
webyrd
Thanks all, appreciate the help
Thanks, I did, all the similar boats with F115's were using 13x17 3-blade SS.
Looked at them, might consider, would rather just loose the foil and get the right prop.
Well, I had figured a 350 RPM increase, what do you think, would I be better off with a 15" pitch? The Titan HR4 in 15" increases diameter to 13-1/4", not sure what that small of a change in diameter would do.
Also found a Stiletto Bay Pro in 13-1/4x16 (another site, iboats evidently does not carry). The reviews I found on the Bay Pro do not seem to be as good overall as for the HR4, quite a few other Stiletto reviews mentioned that they generally seemed to act like they were one size larger in pitch - may end up about the same as the 13x17 HR4. That site also had a considerably lower price on the HR4, anybody know if iboats price-matches?
Anybody know where I can find a three headed coin to help my final decision?
