Wonbigfish
- Apr 29, 2013
- 36
I recently had to replace my 90 hp force. I found a 1997 90 hp with great compression. Mounted it up on a 16 1/2 Palm Beach. Swapped out carbs, new water impeller and ran great. The prop seemed perfect and it was for a year. Decided to replace the aluminum prop with stainless of equal performance. Couldn't get prop off lower unit to find size numbers. Had to cut, beat & cuss it off. Only to find nimbers missing or corroded away. I read several web site sizing sugestions and purchased a used Ballistic 13 1/2 x 17 stainless prop. It just doesn,t have the same hole shot nor speed. I don't have a tach but I think it's running at higher RPMs. I fish the flats of Mosquito Lagoon. It requires a quick jump on plane & enough speed to do the skippy through flats. I am considering a 4 blade 13 x 19 Aluminum or Stainless.
Any comments or suggestions appreciated
Wonbigfish
Wonbigfish
