hi. first time owner long time addict. i boat this boat recently from a guy who used it in a rocky area. the prop has a couple dings on it. i am hesitant to go wot because i wouldnt want to damage the lower end. it doesnt seem to have any vibration or weird noises but i would feel more comfortable with a new prop. will slight curves at the tip of the prop do any damage? Aside from that i have on there right now a black max 14.5" x 21" manufacture says wot should be around 4500rpm. the gear ratio is 2.0 engine is a 3.0 135 hp mercruiser. should i use the exact same prop or should i go with a different one? I use the boat for pleasure cruising right now. also what do i need to chamg it? All new washers or just the prop and a wrench? Thanks for the help!
