Re: Prop selection
The original prop was probably something like 10 inch diameter (or 10 3/8 or 10 1/2) by about 12 inch pitch. Look in the catalogs and here on iboats. Props are listed by horsepower range and engine make and model year. Depending on the year of your Force, prop could be a little different but you still should be able to get a Michigan for it.
And what i posted before is still true: even with a 50, water skiing will be marginal. But if your intent is for primarily skiing, go with a lower pitch prop in the offered range--ie. If they offer 11,12, and 13 pitch, go with an 11 or 12.
