Re: prop selection
I dont have that info.But you can figure it or<br /> a prop shop or good marina.Keeping it simple<br /> you need to know your present rpm.the motors recomended max rpm.the pitch of the present prop then to increase rpm you would need less pitch<br />to decrease decrease rpm more pitch.When reaching your max rpm you should be at your max speed.<br />There are also some special props that will<br /> tweak the most speed out of your motor.Most shops or marinas will let you use/borrow a prop to check the performance.Keep in mind if you<br />increase the pitch you will decrease the hole shot<br />and load performance.Decreasing pitch will improve hole shot and load performance.You need to be careful to not exceed the maximum recomended rpm.
