I know this topic gets beat to death but every boat is different and I have searched most of the forums looking for answers and am now somewhat confused. I have a triton tr 17 with a v4 115 yamaha 99 model. I have a 21 pitch semi-cleaver prop (5500-5900 rpm WOT), a yamaha pro series 22 pitch (5250 rpm trimmed all the way up, rooster tail 1' above motor and chine walking), a tempest plus prop 23 pitch (4900 rpm WOT, terrible hole shot but superb handling). My cav plate is 1 1/2'' above keel. I have a stepped transom (2 inches). The 21 pitch performs the best but with full trim, will run 5900 rpm, puts a rooster tail as high as the motor but doesn't hold the water in the turns very well. It usually revs about 200 rpm's higher. As you trim up, you can feel the boat lift at 4000 rpms and again at 5500 rpms. You can feel less drag as you go above 5500 rpms. The water line will move back about 3 inches once you go above 5500 rpms. I do not have gps for the rpms. Speedo reeds 53 at 5500 rpms and goes up to 56 at 5900 rpms on a long run. I like this prop, I just wish it would hold the water better. The 22 pitch prop will run 57 on the speedo but you just can't stay in it because of the chine walk. It holds better in the turns but not what I would expect from a cupped prop. The 23 pitch 4 blade tempest holds the water like a champ. I would like this prop in the 20 pitch but they don't make it. I like the performance of this prop accept for the hole shot and WOT Rpms. I have used the Mercury prop calc and tried several of the settings. They all calculate my rpms to be 5250 at best and suggest some of the props that I already have. I want WOT rpms to be 5500 at full trim and hold fairly well in the corners. I am running the third hole up on the transom. I do not want to purchase a jack plate (just haven't had any luck with them.) Any suggestions on what prop to use? I can go up one more hole with the motor. It will put me 3/4'' higher. I will mention that the center of the prop shaft is 5'' below the transom. Any help would be appreciated.
