prop shaft bent
rlebla4
I noticed this weekend while turning my prop by hand that there is a slight but noticeable wobble. Should I be concerned with this?
dilligafda
Re: prop shaft bent
YES!!!!<br /><br />Replace the propshaft and have the gears inspected for possible damage. A bent propshaft can cause damage to the bearing carrier and bearings. It's much cheaper to fix it now than after the damage occurs.<br /><br />Good luck! :)
The Marine Doctor
Re: prop shaft bent
You might also want to check with your insurance company, if the damage is severe.<br /><br />That is if you have insured the unit.<br /><br />TMD
wilde1j
Re: prop shaft bent
Prop shafts can be straightened by a good machine shop and it is a way less expensive fix than a new prop shaft.
