sam am I
- Jun 26, 2013
- 2,169
92 Merc 2.5L 175HP SN 0D103921
I think mine is waaay toooo much, I'll put a dial on it in a bit but, in the mean time............
I have read and searched the manual and here, seems to not really be a official spec documented on "prop shaft" end play (push/pull on shaft w/o prop on), anybody ever seen/read one in a merc document/manual/spec sheet? If so, can you print screen me a copy and/or link/quote where it can be found? S&F posts also seem to be not really knowing either.
I have "drive shaft" end play spec, that I found.
Gears/teeth (forward and back) and needles all look actually pretty good, no metal on mag plug (little powdered metal is all). Shifting although seems to be getting a bit persnickety........Seems edgy/touchie to get center and still have forward and reverse lock in good at detents...wants to pop out of reverse/be grindier if I don't go by reverse detent it w a bit higher throttle and come back to detent, then it stays in okay
Thanks a ton!!
Thanks a ton!!
