further
- Jun 18, 2009
- 1,034
Hey all, so weather finally warmed a bit so I rolled the Outdrive out from the corner of the garage to start sanding it down for my refinishing project and noticed an oil spot on the floor. Went to feel around for oil on the Outdrive and there's a bit coming out of the prop area. It wasn't leaking anything prior to winter when I put it to sleep. Changed the oil before I took it off the boat. Could the prop shaft seal go just like that? Difficult to replace?
Thanks in advance
Thanks in advance
