I have a 1991 Mercuriser alpha one series one and hit a rock with the prop last time out. It broke the top off the drive shaft that goes through the water pump. I have the prop shaft bearing carrier out, the shift shaft out but the prop shaft won't come out. Does the water pump shaft have to come out first? There is a nut on the bottom of the water pump shaft holding a gear on but I cannot get it loose. I tried a 7/8" open end wrench but it is rounding the corners off. Any body ever taken one apart and have any ideas?
