Prop Shaft
mwade315
Im having problems getting the prop shaft out of my 200 hp mercury outboard. I have the housing out, but the clutch, pinion gear and reverse are still in there with the shaft.. Any suggestions would be appreaciated
mwade315
Carrier is removed, prop shaft and clutch did not come out with it.. It is very frustrating
Faztbullet
Soory but all you have to do is remove the unit and then remove shift shaft and propshaft will pull straight out. Gears can stay in place....
mwade315
Thanks guys... This is the first time ive had to do anything with my motor. so i figured id take my time and learn as I go...
Appreciate the help
