prop size/pitch
dollarb1
we have a 1996 johnson 150 on a 22 ft hydra-sport deep-v. the prop is alum 15X17. We can only get about 4800 rpm with this setup. we want to go to a ss prop and get the rpm's up to about 5500. what size prop should we be looking for? thanks for any help.
Dhadley
Re: prop size/pitch
You can also gain RPM by raising the motor (increase the X dimension). I would think a 17 on that boat would be close. Try raising the motor a couple of holes and lets see what happens before you spend bucks on a new prop.<br /><br />Good luck!
