Prop Size Question
johnjsa
I have a 1977 Johnson 70 HP motor & am going to change to a stainless steel prop but do not know my existing prop sie. The only numbers I find stamped on it are 508C and 139. Don't know if anyone can help with this but would appreciare it.
Dhadley
Re: Prop Size Question
There should be some numbers near the hub. You may have to remove the nut to see them. <br /><br />Does this prop put you in the correct top rpm range with an average load?
