Re: Prop size question
this is opening a can of worms.
you have a lot to deal with: diameter, pitch, and rake........ just for basics
what are you looking for stern lift or bow lift?
more take off or more top end?
when i had my hub repaired i was talking with the guy at the prop shop (owner and boss) and i thought i half way had it figured out.......... then you talk to an expert.
i dont have any real answers for you as i am no expert, but you need to give more info so the gurus can give you some advice.
something like: current rpms, total boat weight, current speed, current prop brand and size, and what performance you wuld like to enhance.
there are some props that are good for almost everything, but the more versitile the more expensive....... high performance always comes at a higher cost.
i hope you find what you are looking for........ and by the way some prop shops will let you do some trial and error if you do not damage the prop.. or have to special order it.... that goes a long way into finding the correct prop for your boating style.
