prop size question
jbauman102
I have a Volvo Penta 5.7 gxi-e 275HP with dps f2 props on a 26.8 monterey now rider about 5500lbs. It does about 40mph at WOT. I was told I should have f4 props any I would like some advice or opinions please.
steelespike
Re: prop size question
Not a Volvo expert ,wouldn't know a F2 prop if I fell over it but::
We will need you wot rpm and gps speed to get an accurate indication of your setup.
jestor68
You can look up your engine in the Volvo data base; but it appears that the max rpm is 4600 rpm.
It that's the case, it appears that you could step up to the next higher pitch set to reduce your WOT rpm to within recommended limits and gain some speed.
emilsr
Changing from an F2 to an F3 prop set will lower your rpm at WOT by about 200. Changing to an F4 prop set will lower your rpm by about 400.
Bear in mind that in the heat of the summer you'll lose a couple hundred rpm, so see where the revs need to be and prop accordingly. Check the plate on the engine as the rev range (and power output) changed over the years on that particular engine. You'll want to be right at the top of the recommended rev range in cool weather.
