prop size question
roffey
My prop is bent, must have hit the mud..... Any who I need a new prop. My current prop is the one that I got with the boat. Its a 23 inch and WOT I hit 5000 RPM. MY motor is a 4.3 and the recommended RPM is 4800, so I think I am right in the manufacturer specifications. My question is if I go with a stainless prop should I go to a 24 inch or stay with the 23. IMHO, I think I am right on the line for RPM and a steel prop is lighter and might over rev the motor. I do not go WOT normally but every now and then ......
Alumarine
Might be better to ask in the prop section but I always thought that if you go from aluminum to stainless all thing being equal you should go down a size.
Therefore 21.
I'm not a prop expert at all.
Sea Rider
SS is way heavier than alum props, if with a 23 prop achieves 5K revs, going down one size to 22 should achieve same rpm, right or wrong ? If right will need to repitch current one as probably there isn't a 22 pitch market available.
Happy Boating
alldodge
Would need some more info to determine if your slip numbers are correct.
Need drive ratio and a gps reading for mph. Will also need to know if your Tach is accurate, most are not
Otherwise stick with 23, aluminum or stainless and watch you rpm's.
roffey
depending on wind I go from 52.9 to 54.2, on the gps. Tach is 4900 to 5000 depending on how far up the drive is. I trim it until I start to lose MPH. not sure on the drive. I will look around and see what numbers I can come up with.
But you guys think I should go down in pitch, or as AllDodge said just watch the rpm. It sure would be nice if you could test drive a prop first.
alldodge
Using the 4.3 normally has a 1.81 drive and if everything else is correct you have 11 percent slip (using 53 mph), which is not bad. Being a small boat it should be below 10 percent. Many places will let you test a prop, but there are many more that have you lay down a deposit for your next prop
roffey
I would happily put down some cash to test a prop as I am in need of new one. Thanks for the info...
superbenk
PropMD has a pitch exchange program & are great at working with you. I'd recommend giving them a call & tell them your numbers. They'll give good recommendations & work with you until it's right. I've been really happy with them both for repairs & recently a prop purchase.
