Re: Prop Size????
Tommy, the correct prop is one that will allow the motor to rev up to its suggested RPM at wide open throttle. I would try to arrange to borrow some props for trial runs, and then buy the one that meets that criteria. My guess is that you will need a 17 or 19 inch pitch prop for that boat/motor combo. I would start with these and adjust up or down. Remember, each 1 inch change in pitch will cause about a 200RPM change. So it your motor turns 4800 RPM with a 19 inch pitch prop, a 17 inch pitch prop will turn about 5200RPM.
