I have a '95 3.0L OMC cobra in a 17.5 ft fiberglass boat and new to boating. Manual calls for 14.5x19 prop as standard, came used with 15x17 prop on. Manual WOT calls for 4,200-4,600 rpm, with the 15x17 I can get to maybe 4,000-4,200. Barely gets 1 average skier (2 skis) out of the water (with 2 adults in boat). Engine was previously rebuilt before purchasing. Isn't the 15x17 prop better than 14.5x19 for hole shot and getting a skier up? Since I can barely get a skier up I'm thinking I should change to maybe 15 pitch, but that is getting pretty far from the 14.5x19 prop the boat is supposed to have. Or would I be better trying the smaller diameter 14.5x19 prop the manufacturer lists? Maybe it lost some power with rebuild? In looking at some of the posts, I should hit a prop shop that lets me try a few. Would any of you experienced boaters recommend going to maybe a 15 pitch or staying put? Also, is there much difference in 14.5 vs 15 diameter? Thanks!
