carbineone
- Feb 11, 2010
- 268
Ok I have a question.In my avitar you see I have a little 10 GW Invader mini speedboat.I just put a 1974 Evinrude 50HP on it and the engine came with a 13x19 pitch prop.The RPM range in my manual says 5000 to 6000 WOT.What your best guess how this prop will perform or should I just change it before I even attempt to take it out if it will be way off?..The boat of course is very small and light so from reading here if I understand correctly I may need the high pitch.Anyway take your best guess as what you think.I am going to install a Tach also before we take it out with the new motor this weekend...Just wanting a estimate what to expect...Thanks
