Re: Prop Size
One that will get you to around 5800 RPM's WOT with a normal load on the boat. The only way to really know which one is the correct one is to run with what you have and check RPM's. I'm guessing a 15"-17" pitch would be close. Also, any prop shop can get you close and usually will exchange it if need be...
