Re: Prop slippage
It's raining outside so I came back in and decided to dig into your question.
I went to old-omc.de site which is a super site a guy put up for us with old catalogs from OMC over the years.
Anyhoo I picked a 1970 60 hp Rude and it's specs are:
RPM: 4500 to 5500
Gear ratio : 12-29 which translates to 2.41:1
Weight 202#
Standard prop 13 1/4 x 17
You said 11 1/4 x 17 in your text; I'm thinking you meant 13 1/4....need to clarify as it could help in the answer.
The BAM slip calculator said that you were right on at 26 mph with 31% slip (It actually calculated 33%). It said that your non slip speed should be 39 with the specs you gave and I dug up. A reasonable slip of say 15% with a light load on that boat would yield a speed of 33 mph which is very reasonable and do-able.
Either you have a bad prop, more boat load than you think, a poor efficiency hull (which that Glastron is not), barnacles or other crud on the hull, or your speedometer or tach is/are in error.
You are 300 rpm over max first off. Don't know how that engine handles that. Since you seem to be there with a full load, when sporting about by yourself you would be way over the upper WOT rpm limit.
On the boat: Looks like '67 is the first year Glastron made the trihull and the closest to 16' is the 15' 6" Sportster. The weight per the spec sheet it either 500 or 600# empty(can't read the data very well)....pretty light boat, even for glass.
See:
http://www.classicglastron.com/67gl-specs-web.html
So your guns are loaded with info; time for some more feedback from you.
Mark
