My rpm was too high so I checked the hub by spinning the prop ( my boat is trailered)manually. I put the gear on forward, the engine is left-handed, but I have not really observed what direction the prop spins. The hub was bad but in the process of doing this investigation, the prop shaft turned freely clockwise ( I was facing the prop) and counterclokwise with some force. Again, the forward gear was engaged. Any comments here? Is my forward gear needing replacement? It is my assumption that the prop shaft would not turn at all under this circumstance. Hope it's not bad news.
