Re: Prop stuck on
Use two prybars to put a little pressure on the prop.With the nut backed off so it is flush with the end of the shaft,whack the shaft end with a hammer with a block of hardwood to protect the shaft.A good sharp hit with the hammer should dislodge the prop.You need two people to do this properly.
Phil
