Prop test results
travis g
I was awful wrong. With the new tach installed my 4bl 18p is turning 6000wot with 2 people and a full tank. The 16p I Tried was a disaster. Half throttle hit 6k. What would a 19p 3 blade do for me? Wouldnt mind a little more speed but I'm not willing to lose very much hole shot.
V153
Re: Prop test results
What boat? How many hp? How fast?
BonairII
Probably gonna need to go much larger than 19p if you're redlining at half throttle with a 16p.
travis g
Thought maybe a 4bl 18 and a 3bl 19 would be close.
Tiderunner88
Just went from Black Max 19 to the new Spitfire 19 four blade- same rpm @5300- same WOT 40. You could pitch up and try 4 blades, the hole shot is excellent with a 115 merc.
Texasmark
Unless you are carrying around filled 55 gallon drums, you are way over powered for that boat. I used to rent a 20 footer and run it with my 9.9. Course you can watch the gals on the Alligator show. They have a john of that general size with a 115 on it, as do the guys with the canvas top. On prop pitch change, the number is about 150 rpm per inch down if you increase pitch and up if it's the other way. The 4 blade is usually reserved for high loads aft on heavy boats without a very good planing surfaced hull. Your john is about as good as it gets in terms of easily planed hulls.
But doesn't matter what you buy. What matters is if it works for you or not!
Mark
travis g
I do carry a lot if weight at times. It was rigged with the large motor by the state. It used to be a fisheries boat for Florida.
sweet addiction
If hole shot is your main concern then stick with a 4 blade. Are you talking stainless or alum.?
jestor68
That's because the info you provided initially was wrong. :facepalm:
So you know, your WOT rpm range is 4500-5500 rpm.
Going from 4 blade to 3 blade add one of pitch. So if you are turning 6000 with an 18 4 blade and go to a 19 3 blade, you will likely turn the same rpm(or close to it).
So, what do you need to do to lose 500 rpm and switch to a 3 blade prop?
Rule # 1: one inch of pitch equals 150-200 rpm change.
sweet addiction
And going from aluminum to stainless in the same brand and prop configuration will loose I think if I am remembering this correctly.......somewhere around 200 rpm.
steelespike
I still wonder why it won't carry 8 men and plane? What is the actual all up weight.
Your surely not going to solve your weight issue with more pitch.
The boat must be way over its rating with 8 people.
Again my 25hp 18 ft Crestliner tiller bare utility, about 800 lbs rigged, would plane easily with 6 adults
averaging about 150 lbs. Probably about 20 mph.I'm sure your much heavier but at almost 5 times the hp.
I do wonder if your 18" prop is actually an 18?
travis g
Taking the prop to a prop shop on Nashville. He is going to add cup to the blades. It is stamp m18. He said adding cup will help sow with the rpm. I found a corroded wire form the power pack yesterday. I believe I may be losing power under heavy load due to elec breakdown. It will plane out with a heavy load but it bogs an takes a minute, and its not real consistent.
steelespike
Adding cup will reduce rpm but it's usually like adding pitch.
The right cup might help hole shot.
