hi and how are you? i have 1995 120 force. currently it gives me 33mph max speed. i like to go faster than that. will changing my prop increase my speed and accelaration?. if yes, what type or kind of prop should i put in? two blade, three blade, four blade etc, what pitch, tainless steel or aluminum? i want to put in a 26 pitch 13.5" in diameter with three blades.
At 10mph my bow rise up to the air to the point that i can't see where am going. i will have to stand to see where am going but as speed increases it comes down. is this normal or something is going on with my engine.
my boat doesn't have a tacometer, so how do i check my boat RPM at full throttle?
is it normal for me to have to crank my engine several time like two to four times or sometime even more time for the egine to fire up/ start up. but whenever i turn the key it turns over, the flywheel spins and the engine cranks. The battery is fully charge. sometimes one turn starts the engine.
thanks
thanks
