Prop Upgrade on 235
dhym
I am running a Johnson 235 (85) on a 1998 Glastron 17' with a 19 pitch prop. When I'm pulling a skier and I have 2 others in the boat with me it does not pop the skier up right away probly takes 10-15 seconds to plane out. I am looking at buying a 15 or 17 pitch and am not sure which one to go with same thing on size. What is the difference between a 141/4" and 15"? Any help would be appriciated.
D
DJ
Guest
Re: Prop Upgrade on 235
What is your wide open throttle RPM?
jimmbo
How big is the skier and how small is/are the ski/skies?
emdsapmgr
The diameter of the prop is of no consequence. The prop designers vary the diameter in order to maintain the correct pitch.
Dhadley
Larger diameters bite, or hold the water, better. They also allow for a higher engine mounting (X dimension). A higher X dimension means less drag (less gearcase in the water) and that means better efficiency.
dhym
RPM: WOT 5800 RPM<br />Skier: Single Ski and about 190lbs<br />Pasengers: 700 lbs
Dhadley
Since this prop will be a ski / spare prop I'd suggest the 15. The lower the pitch the easier it will pull the skiier out. Obviously without a skiier and cruising it will rev up past the point of being efficient. But that's what your existing prop is for.<br /><br />14 /14" diameter is fine but a 15" diameter will have even more pulling power.
dhym
Can someone tell me how many splines a 235 has?
jimmbo
Take the prop off and count them
JB
Moving to Prop Forum.
