Prop Ventilation Issue
RomanRegal
I have a 1987 Regal 233xl. When I begin to trim the boat out on plane, there will come a time when the engine begins to rev up quickly. I have to pull back or trim down. I am not trimming up excessively. I am running a 15x19 Alum prop. Any suggestions. Thanks Roman
Ross J
Re: Prop Ventilation Issue
Not knowing that boat I assume you're wearing the correct prop for the conditions.<br />I guess since you've got onto the plane that it isn't a spun hub. Rather it sounds like cavitation.<br />If you have a jack plate then try and lower the prop height and see if that works. If you don't have a jack plate then beg, borrow, or buy a decent Dolefin or Permatrim or some other type of metal plate that bolts onto the outboard and stops that problem.<br />Ross
JB
Hi, Roman.<br /><br />If your prop is ventilating (sounds like it is) you are trimming out excessively for that prop and that boat balance.<br /><br />Sometimes a shorter pitch prop can reduce this, but the better solution is to get your propshaft a bit deeper. Maybe a bit more of the weight aft?<br /><br />Good luck. :)
