Prop vs Crank HP
mrbyll99
I recently purchased a 1997 Bryant 192 with a Mercruiser throttle body EFI 5.7L that states 220 prop HP. I cannot find the crank HP rating anywhere...any ideas?
It runs very well (low 50's) but I am wondering if it is possible to re-chip and re-jet that engine for a little more performance?
Thanks
John_S
Re: Prop vs Crank HP
Thanks
Depending on drive, add 25-30hp to get crank hp. But, it is better to compare at prop hp.
No re-chips and programming if possible is very expensive. There is little you can do to an injected boat engine, without a large expense.
Nope,.... Ain't gonna Happen.....
Prop Hp,... Crank Hp,... They're All just #s....
For you to step Up in Hp is goin' ta be a Major refit...
Like to a BBC...
