prop woble
mfo
I was looking at a 1991 150hp pro v to buy and i noticed that it had a little movement side to side probably less than an eigth of and inch but most other props i have grabbed had no movement i rode in the boat and it runs fine and doesn't seem to vibrate at idle is this something to be concerned with ? it has a stainless prop
mark
Mueller1956
Re: prop woble
Pay close attention to the Center of the prop shaft if it is off an 1/8" you might ask for a replacement or take a reductioin in price. Be sure if you go with that one to have the lower unit checked out.
Good luck!
