prop
ddennis
Re: prop
You'll burn up your motor. If its sitting that high the intakes for the impeller (water pump) are out of the water. Even if they were in the water...being that high up you will not get any thrust..only cavitation
ddennis
Re: prop
Probably not. What engine do you have and what kind of boat is it on?
rooster1
Re: prop
its a 25 hp with on a 15 ft runabout not enough power but all i could afford at the time it had a 35 hp evinrude on it when i got it tore it down and found a broke crank i just went out and looked again the top of the propeller is almost evev with the bottom of the boat transome not the strongest dont think it could hold anything over 50 hp what can i do to lower propeller cut down the transome a little?
tashasdaddy
Re: prop
that or a mini jack plate to lower it. they are usually to raise the motor but can work.
rooster1
Re: prop
how does that work it mounts on the transome and mount the motor on it?
Silvertip
Re: prop
It isn't the position of the prop you should be looking at. The antiventilation plate (the flat plate just above the prop) should be even to an inch above the bottom of the hull.
ddennis
Re: prop
Dont cut the transom...great way to ruin the boat. Tashasdaddy's answer is the best one and cheaper than getting a new motor!
ddennis
Re: prop
Yep. It bolts to the transom, you hang the motor from it, and then you can adjust the motor up and down a couple inches, how much depends on the jack plate you get.
