prop
laker_jim
I just got a 1988 bayliner capri 20 footer it has a OMC Cobra motor and stern drive.what i like to no is the HP and what size the prop has to be = the prop i took off ( it busted ) is stamp on it is ( 13 3/4 x 15 ) the number is 391198 and it has 13 spline is this the right prop for this unit <br /><br />thanks jim
RatFish
Re: prop
After you read Dunaruna's link and figure out what prop you need, go to iboats prop finder. They are running a good sale on props now. IMHO, The Hustler Aluminum would be good for your application.
summit1
Re: prop
Will a prop from an OMC outdrive fit on an Alpha 1?
RatFish
Re: prop
summit1,<br /><br />I doubt it. Post your question as a new topic. You will get a better response.
Re: prop
Depending on the Year of the OMC,<br />Yes............<br />But,<br />A Merc. Prop, will Not fit on the same OMCs.......<br />Spline Depth is Different..........
