Propeller for 1951 25hp
what66
Hi I found out my propeller bushing is bad the shaft just spins when engaged.<br />so I need a good propeller.
Paul Moir
Re: Propeller for 1951 25hp
Always something isn't it what?<br />How heavy is the boat you're goint to put it on? What kind of boat is it?<br />A prop shop can fix your propeller if you want. Iboats sells brand new ones that fit though.
what66
well it's a 14ft fiberglass boat.<br />I think it weights abouht 500pounds but thats just a guess.
tgissel
Sometimes with older propellers like that when they try to press in the new bushing they will crack the hub. Just experienced this the other day. Good Luck!
what66
well the prop shop says the bushing is no longer avable. :( <br />but I was able to repair my propller using an old propeller I had lying around.<br />But I would still like to get a good used one.
