Propeller nut SPACER -- need help fast!!!
does anybody have one of these that i can buy for a 1996 johnson ( J60TLEDR) 60 hp motor with large gearcase??? or does someone know of a marina open on a sunday-holiday weekend so i can go get one??? i'm located in SPRINGFIELD VERMONT AND WILLING TO TRAVEL ALITTLE!!!
Bob_VT
Re: Propeller nut SPACER -- need help fast!!!
I know Woodards in Bomoseen usually has them on the shelf. I would call first but they should be open tomorrow.
If you have the prop nut..... as a temporary fix you can a large washer that fits the shaft and use that..... make it temp or it may rust. Most anyplace that deals with any I/O or larger outbaord should be able to fix you up.
yes !!! i forgot Woodards in Bomoseen. they will get a phone call in the AM!!
thanks!!!
rolmops
Don't panic ( r-Douglas Adams)
You can always get a few washers.It is not pretty but it will do the job.
kenmyfam
Temp fix with any washers on hand will work to get you through, however change out for the real thing as soon as possible.
