Propeller Size
Che Palle
Hello Friends,<br /><br />I wanted to replace my prop on my 19' sea ray seville 140hp mercruiser boat with something that has alittle more performance without putting too much strain on the engine... If anyone could get back to me with a size or type, id greatly appreciate it.. <br /><br />Thanks!<br /> Lou
BMDODGE
Re: Propeller Size
what size prop do you have now ?? what's you rpms at WOT ??? Welcome to the Board - Bruce
jch7450
Re: Propeller Size
If im right,your boat is about the same weight as mine,19 glastron the best prop i found is a michagan wheel 13/19 will give you the best overall hole shot and top speed
tommays
Re: Propeller Size
i have pretty much the same boat and it depends on what type of boating you want to do<br /><br />fulley loaded with 4 or 5 people i need a 15*17<br /><br />out buy my self want to go fast 14*19 or mabey a littel bigger<br /><br />the 140 motor does not have the power for a one prop solution<br /><br />tommays
