I have a '95 3.0 L OMC cobra in a 17.5 ft boat and new to boating. Manual calls for 14.5x19 prop as standard, came used with 15x17 prop on. Manual WOT calls for 4,200-4,600 rpm, with the 15x17 I can get to 4,000-4,200. Also barely gets 1 average skier (2 skis) out of the water (with 2 adults in boat). Engine was previously rebuilt before purchasing. Isn't the 15x17 prop better than 14.5x19 for hole shot and getting a skier up? Since I can barely get a skier up I'm thinking I should change to maybe 15 pitch, but that is getting pretty far from the 14.5x19 prop the boat is supposed to have. Maybe it lost some power with rebuild? Would any of you experienced boaters recommend going to maybe a 15 pitch or staying put? Also, is there much difference in 14.5 vs 15 diameter? Thanks!
