PROPELLER TEST RESULTS.
walleyehed
As this is copied from Wordperfect 10, it didn't format perfectly, I apologize for that...the prop, manufacture, rpm and speed are listed after each prop and if you read carefully, you can extract those numbers.<br />I hope this is of some use to all who read it. I learned many things about blade design during this testing and some designs are just not suited for some applications, but I did get a very good feel of how each design performs and where it is best suited.<br />If you have any questions, please, ask away.<br />Remember, these are all SS props. <br /><br /><br />PROPELLER TEST RESULTS<br />FOR 3-BLADE STAINLESS, THRU-HUB EXHAUST DESIGNS.<br /> <br />BY KENNY SANDERSON<br />2 PROPELLER DESIGNS WERE THE FOCUS OF THIS TEST<br />#1. WAS TARGETED FOR HIGH-END PERFORMANCE, THRU-HUB DESIGNS FOR HIGH-PERFORMANCE, OUTBOARD TYPE HULLS.<br />#2. WAS TARGETED AT THE HEAVIER, STERNDRIVE AND CENTER CONSOLE-TYPE BOATS WHERE LARGE BLADE AREA IS REQUIRED FOR BEST PERFORMANCE.<br />THE BOAT COMBINATION USED FOR THE TESTING IS AN 18FT., ALUMINUM DEEP-V WITH A 6 INCH JACKPLATE WITH TRANSOM MODIFIED TO HANDLE A 2.5L, 200HP EVINRUDE.<br />MOBSTER TABS BY NAUTICUS INC, WERE INSTALLED TO ALLOWED THE SPEEDS ATTAINED<br />DURING THE OPERATION OF THIS BOAT AND CREATED A SAFE PLATFORM WITH EXCELLENT HANDLING QUALITIES.<br />SOME PROPS ARE LISTED TWICE, NOT ALL PROPS WERE TESTED ON THE SAME DAY, BUT EACH PITCH GROUP WAS RUN ON A SPECIFIC DAY, SO DATA FROM EACH PITCH WILL BE UNIFORM TO CONDITIONS.<br />TEST CONDITIONS ARE AS FOLLOWS FOR THE DEEP-V ALUMINUM PLATFORM.<br />FOR LOAD SIMULATION, SAND BAGS WERE USED FOR WEIGHT, POSITIONED WHERE PASSENGERS WOULD NORMALLY BE.<br />FOR THE HIGH-PERFORMANCE PROPS, 19P AND UP, 200LBS OF SAND BAGS WERE PUT WERE THE PEDESTAL FOR THE LEFT SEAT WOULD BE.<br />FOR 17P AND SMALLER, 600LBS OF SAND BAGS WERE ADDED TO SIMULATE A HEAVIER TYPE BOAT.<br />FOR THE LARGE BLADE AREA PROPS, 200LBS OF BAGS WERE PLACED IN THE LEFT SEAT POSITION AND 400LBS IN THE REAR WITH AN ADDITIONAL 200LBS FORWARD OF THE CONSOLES.<br />ALL REQUIRED GEAR PLUS 175LBS OF TACKLE, A 24 VOLT 62 INCH MINNKOTA TROLLING MOTOR WITH 2 GROUP 31 BATTERIES WERE ALSO LEFT MOUNTED TO SIMULATE ACTUAL, REAL-WORLD CONDITIONS.<br />PLEASE KEEP IN MIND, MY RESULTS ARE UN-BIASED, I WAS NOT PAYED OR REIMBURSED IN ANY MANNER TO TEST THESE PROPELLERS, THIS TASK IS ALL MINE AND TOTALLY INDEPENDENT OF ANY AND ALL MANUFACTURERS.<br />THE HIGH-PERFORMANCE PROPS WILL LIST TOP RPM AND SPEED VIA GPS. THIS LIST WILL ALSO INCLUDE VENT HOLE SIZE IF SO DESIGNED BY FACTORY.<br />HOLE-SHOT CHARACTERISTICS WILL BE LISTED AS WELL.<br />IN SOME CATEGORIES, THERE WILL BE PROPS OF 1" TO 2" DIFFERENT PITCH AS REFERENCE PROPS FOR COMPARISON.<br />ON THE FOLLOWING PAGES, THE BOAT, PROP MANUFACTURER AND SIZE WILL BE LISTED, WITH SPEED VALUES AND RPM. HOLE-SHOT AND/OR VENTING HOLES WILL BE NOTED AS WELL. ALL PROPS WERE RUN TO MAX EFFICIENCY AND ONLY TOP FIGURES WILL BE LISTED.<br /><br />ALUMINUM DEEP-V, 200 EVINRUDE, PERFORMANCE PROPS<br />MANUFACTURE RPM MPH NOTES<br />OMC 15X17 6350 48.1 GOOD HOLE-SHOT<br />TURBO1 14.25X17 6300 50.9 “<br />STILETTO 14.25X17 6300 50.2 “<br />VIPER 14.875X17 6200 48.8 “<br />BALLISTIC 14.75X17 6150 46.6 VENTS EASILY WITH TRIM<br />RAPTURE 14.25X17 6250 47.4 VENTS ON HOLE-SHOT<br />MANUFACTURE RPM MPH NOTES<br />RAPTURE 14.25X19 <br /> 6100 <br /> 49.9 <br />MWC 14.5X19 6100 52.0 GOOD HOLE-SHOT<br />BALLISTIC 14.5X19 6000 50.6 HOLE-SHOT SLOWER<br />TURBO1 14.25X19 6050 53.1 <br />OMC SST 14.5X19 6100 52.1 <br /> <br /> <br /> <br /><br />RAKER 14.5X20 5800 54.7 3/8" VENTS EXCELLENT HOLE-SHOT<br />MANUFACTURE RPM MPH NOTES<br />MWC 14.25X21 5750 53.9 FAIR HOLE-SHOT<br />BALLISTIC 14.375X21 5700 53.2 POOR HOLE-SHOT<br />VENTED 3/8"<br />OMC SST 14.25X21 5700 54.2 <br />VIPER 14.875X21 5650 54.4 GOOD HOLE-SHOT 5/16" VENTS<br /><br /><br />MANUFACTURE RPM MPH NOTES<br /> <br /> <br />TURBO 14.25X21 5700 55.4 <br />MANUFACTURE RPM MPH NOTES<br />MW EDGE II 14.25X22 5700 54.0 <br />RAKER 14.5X22 5600 55.1 <br />MANUFACTURE RPM MPH NOTES<br />TEMPEST +14-5/8X23 5400 55.7 GOOD LIFT<br /> <br />MANUFACTURE RPM MPH NOTES<br />RAKER 14.5X24 5250 56.1 HIGH CYL HD TEMP<br />SCORPION 15-1/8X24 5250 56.3 “<br />BALLISTIC 14.5X24 5200 54.7 VENTS EASY AT HEIGHT<br />MWC 14.25X24 5200 54.9 <br />MANUFACTURE RPM MPH NOTES<br />TURBO 1 14.25X25 5050 55.4 HIGH CYL HEAD TEMP<br />RAPTURE 14.25X25 5100 55.0 “<br />MANUFACTURE RPM MPH NOTES<br />SCORPION 15-1/8X26 4900 56.1 STILL FAIR HOLE-SHOT<br />TEMPEST 14-5/8X26 4950 57.3 GOOD HOLE-SHOT WITH PLUGS REMOVED<br />BALLISTIC 14.5X26 4900 54.9 <br />RPM BELOW NEAR 5200 SHOWED HIGHER THAN NORMAL CYLINDER HEAD TEMPS AND HIGH FUEL CONSUMPTION <br /> <br /> <br />HEAVY LOAD PROPS <br />MANUFACTURE RPM MPH NOTES<br />MWC 013052 15X15 6550 42.1 PUSHES 800LBS OF SAND BAGS LIKE THEY ARE FILLED WITH AIR<br />LEXOR 15.75X15 6500 41.9 “<br />MIRAGE PLUS 15.75X15 6500 41.7 “<br />MANUFACTURE RPM MPH NOTES<br />OMC 431930 15X17 6300 44.6 SLOWER HOLE-SHOT<br />LEXOR 15.5X17 6250 45.2 <br />VENGEANCE 14.5X17 6300 44.8 LITTLE SLOW OUT OF HOLE<br />BALLISTIC 14.75X17 6100 44.1 NOT A GOOD LOAD PROP<br />MANUFACTURE RPM MPH NOTES<br />MWC 14.5X19 5850 47.6 SLOW HOLE-SHOT-NO VENTS<br />VENGEANCE 14X19 5850 46.9 <br />MANUFACTURE RPM MPH NOTES<br />MIRAGE+ 14.75X21 5500 48.6 HOLE-SHOT BETTER THAN EXPECTED<br />LEXOR 15X21 5500 49.1 HOLE-SHOT AS ABOVE WITH GOOD MID-RANGE <br />TURBO 1 14.25X21 5550 48.0 VENTED BUT PRETTY SLOW HOLE-SHOT WITH MAX LOAD<br />VENGEANCE 13.75X21 5600 48.2 NO VENTS AND SLOW HOLE-SHOT, BUT GOOD MID-RANGE
Ron G
Re: PROPELLER TEST RESULTS.
Thanks kenny,thats very impresive.whats the max rpm for the 200 evinrude?I'm a little better than i expected then,you seen my 175 faststrike thread?Thanks again for the info im going to coppy it off and save it for ref.if thats alright with you.
walleyehed
Max RPM with my 200???I don't know for sure, but the book says 5750. It was built to take whatever I give it... :D <br />Copy what you'd like. That's why it's here.<br />Always keep in mind, each prop will react differently on my hull, than it may on yours.
Ron G
Thanks kenny,i figure the 200 would do whatever you wanted it to.
imported_bjs
thats good test results sounds like that evinrude pretty strong motor.
stevens
Very impressive, Walleyehed! More than 40 different props listed. I don't think I have seen such a comprehensive prop test published anywhere on the net, and certainly not by a qualified & unbiased third-party tester. This really ought to be published properly.<br /><br />Anyway, thank you for your generosity in sharing this.
walleyehed
It was fun...<br />Come spring, I have a few others to run that aren't out yet, so we'll see what next year brings.
nevd
Thanks very much Kenny - great information and a big service to the forum.
bayman
Awesome stuff! This obviously took a lot of work and a decent amount of time too! I'm sure it will be very helpful to many :)
I started a new thread. Walleyehed, I will find the prop numbers and post them on the new thread. THANKS !
Got a Boat
Are there any Prop-Finder in the net for my 40HP Mariner on 15foot Runabout?<br /><br />I realy would like to upgrade to a bigger boat, but my garage is too smal.
walleyehed
Got a Boat, the best prop finder is a tachometer.<br />We need to know what the recommended RPM range of the engine is, and what The actual RPM is with the prop you have now.
Jdeagro
iboats.com Partner
Kenny;<br /><br />Nice Job! And lot's of work. The members should be greatfull to have this info.<br /><br />I noticed that you ran the test with the Mobster Tabs (Smart Tabs) working. Given the current and popular thinking that Props are the sole answer to boat performance ( I know you do not think this way), I was wondering why you did not run the boat with the Mobster Tabs disconected (non functional? I would suspect that the results would have been significantly different.<br /><br />Actually I would like to see the difference between the best performing props without Mobster Tabs and with Mobster Tabs. See, once you start something it seems to never end. I am not suggesting more work. You have already put in many hours on this project. Regards<br /><br />JOhn
walleyehed
You bring an excellent point to the table here, John, and as I think about it, yes, it would be interesting to know those differences, and when I get the chance, I will run several of the props I still have without the Tabs and see what we get. I need more excuses to get on the water anyway!
ufm82
Master Chief Petty Officer
walleye- not to be confrontational here but according to your own test results, the Merc props seemed to outperform most others. Your comments?<br /><br />UFM82
walleyehed
One manufactures prop that I tested outran everything I tested and posted, but, the manufacturer asked that I not include that prop for reasons beyond my control.<br />If you will notice, the Turbo1's and 2's were very close in the High performance props and the Tempest 23P was only .3mph faster than the Turbo1 in a 21P!!!!<br />In the heavy load tests, the Solas props get the edge...<br />I have nothing against Mercs High performance props, the Tempest in particular.<br />Although I cannot tell the pitch and diameter, but I can tell you nothing, and I MEAN NOTHING will touch a Turbo TXP for speed in a given pitch range. The Tempest is a grea PROP, available in many sizes and uses the flo-torqII hub to fit about anything, but you won't find a discount price on a Merc prop, nor will you find a Merc prop that will leave a TXP Turbo. Now, I'm not saying go put a TXP on something that doesn't respond well to over-all lift, and the prop must surface for best results, but then ALL high performance props I tested run best through the surface, indicating they are not very good sterndrive props...thats where the Lexor, Mirage, Vengeance, some of the MWC props come in to play.<br />Merc SS...Great props in their high-end designs.<br />Please keep in mind this test was only for 3-bld SS thru-hub.<br />If things come together for early spring, I hope to have some testing lined up for 4-bld SS.
Texasmark
Hi Kenny,<br /><br />Phew man you've been busy.<br /><br />Couple of questions with regard to your initial testing for the High End Performance Boating runs:<br /><br />Your comment: "Although I cannot tell the pitch and diameter, but I can tell you nothing, and I MEAN NOTHING will touch a Turbo TXP for speed in a given pitch range." This raises a couple of questions:<br /><br />You had a 6" jack plate. You have said that Turbo1 runs better than others jacked up. Well what can you say about it before you bring the prop out of the water? Like I have a fixed transom mount and my cav plate is 1" above the bottom of the boat. <br /><br />I'm currently running a Ballistic 13( ) x 21 and I think I am getting real good bite with my aluminum padded bass boat; really fast hole, excellent med rpm to WOT acceleration, what I think is real good bite in turns, (doesn't blow out even on goosing in the turn, revs, but doesn't loose speed...just the opposite) and real good top end. <br /><br />My WOT rpm's are still above 6000 and WOT rating is 5000 to 5500 so I am shopping for a prop cause I don't like running around with the throttle sitting at 3/4 wide open....to get the 5500 and the engine sounds much smoother where it is supposed to run. <br /><br />From playing with the prop calculator, it looks like my 49mph is about all I am going to get from this rig. Propping up will only drop the rpm's, not necessarily add much to the top speed, unless in doing so (propping up), the hull lifts more and the drag drops causing the slip to drop.<br /><br />Next. I was really impressed with your data about heat and low fuel consumption with regard to low rpm's. I don't know what your WOT engine rating is, but you ran from 6350 down to about 5000.....quite a range. <br /><br />You know, you "old timers" on here keep harping about lugging a 2 cycle. Well here you showed us why. I'm assuming the the high temp relates to baking oil on pistons, rings, and cylinders, requiring decarb and all, not to mention poor fuel economy. This should be a real heads up for everyone reading it that has a boat; especially a heavy one. <br /><br />I'm convinced by what you say, as my engine is getting super fuel economy and carbon doesn't seem to be a problem (although I have started adding Sea Foam to my gas).<br /><br />Thanks for the input. I know it will help a lotta folks in their propping decisions.<br /><br />Mark
captnpgn
Kenny, I'm glad you mentioned that there is a distinction between the props you tested and their application, and props for stern drive use. I was wondering if there is any data on specific through hub exhaust prop brands/models tested for stern drive applications or are you just familiar with design characteristics that make certain props more suitable for stern drives. Specifically for brands you mentioned on1/17/06. Thanks
