Propeller????
tommymoe2002
Happy Holidays everyone. My question is I have a 1996 Bayliner Trophy 20 ft with Force 120 runs okay. What size and pitch propeller should I use if I'm using the boat for fishing? Also whats a good make for stainless steel :p
roscoe
Re: Propeller????
The proper prop should be selected based on the maximun rpm the engine reaches at full throttle. The rpm should be within the manufacturers recommended range.<br /><br />For more info on "WHY", click this link:<br /><br /> http://www.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=36;t=000015 <br /><br /><br />So if your current prop is getting you in the recommended range, then you are good to go.<br /><br />If you are at the high end of the range, you will get a better holeshot and come onto plane easier.<br /><br />If you are not able to get into the range, you run the risk of over stressing your motor.<br /><br />So, what diameter and pitch is your current prop?<br />WHat rpm's do you reach at full throttle?<br /><br />You asked which prop for fishing. Do you plan on trolling with this motor?<br />If so, prop the motor to reach the higher end of the recommended range. If the boat goes too fast at idle, then check into getting a drift sock to slow the boat down for trolling.<br /><br />The recommended range for your motor is 4750 - 5250 rpm.<br />Aim for 5200 rpm with your normal load in the boat.<br /><br />If you post what your current rpm are, and your prop size, we can recommend what size prop would be better.
