Propeller
Pmon
Hello. I’m new to boating and I’m trying to find out if my boat has the correct propeller on it. The engine is a 5.7l omc V8. It’s about 20 ft long. The propeller on it at the moment is 141/2x 19 3 blade. But if I have any weight on the boat it struggles to get up on plane. It’s not a new prop it has a few chips on it. Would that be the problem or is it just to high of a pitch. I want to buy a new prop but do I buy the same one that’s on the boat or change it? I’m not made of money so I don’t want to be wasting it in the wrong prop. Thanks
First, welcome aboard
A 19p would actually be fine if not underprop'd with a healthy motor?
Start with a compression test
Thanks. Compression test is all good. All up around 175 psi
You need to check your gauge or you have oil in each cylinder
A new motor will have 150 psi. To get 175 psi, you would need to have a compreasion ratio of 12.5:1 (that is drag motor territory, boat motors are 9.4:1 or less)
Pmon
Pmon
The boat is 1984 so I’m guessing the engine is around the same age. I tried two different gauges and got the same results. It’s just very sluggish fully loaded.
