Propellor for older 19' Reinel
islander46
Hello- I have a mid-seventies vintage Reinel i/o with a 120 HP Mercruiser. A great boat when it all works well! It is old, so propbably not the strongest engine, but it has worked before and I hope it will again.
I have a long-standing issue with the boat not being able to plane out when more then two people are in the boat. I have fiddled with this for years now without a good answer and I would love to sort it out!
I have three Hustler props I bought years ago as a replacement for the Mercruiser prop, and none of them seems right. Can anyone weigh-in on which would be the "right" prop for this boat?
The choices:
14 1/4" X 19
14 1/4" X 17
14 1/4" X 15
Perhaps they are all wrong!
Any and all comments are welcome and appreciated!
THANK YOU!
- Bob T
islander46
Re: Propellor for older 19' Reinel
Thanks- sorry I missed it!
1) Performance issue you are trying to correct.
Trying to get the speed of the boat/RPM's of engine high enough to plane when more then two people are in the boat.
2) Current prop manufacturer, model, aluminum or stainless as a minimum.
Hustler aluminum prop HU1515A
3) Current prop diameter and pitch (required).
15 1/4" X 15
4) Wide open throttle RPM and speed with an average load (very helpful)
3600 (from memory)
5) Engine/drive make, model, year, and HP
Mercruiser 120HP 1972 (From small aluminum tag bolted to engine block:) 1336-3594A1
6) Boat make model, year, length and weight
Reinell Model RV-2000 I/O 1972 19' long,
According to aluminum tag on boat: "1700 lbs for persons and extra gear..."
THANK YOU
- Bob T
steelespike
We need that info Bond-o suggests.
It is very likely that you have a motor or setup issue.
I feel the boat should work with a 19" or 17" prop the 19 might struggle with water sports but should plane easily with more than 2 people. speed with a 19 should be about 35 or more.A 17 should handle even more people and do well with waterer sports.
get us that info we'll get you sorted out.
15 1/4" X 15
3600 (from memory)
THANK YOU
- Bob T
Ayuh,.... If that's All she'll pull, with a 15" prop,....
I'm guessin' you've got Serious motor problems, or the Wrong gear ratio in the drive....
The drive ratio should be 1.98:1....
steelespike
Agreed,Your gear ratio may be stamped on the out drive somewhere.
I think a compression test is in order.If you know how to change plugs you can do a compression test.?
islander46
I will look for the gear ratio on the outdrive, and I will do a compression check. It will take me a few days to get the compression check done though.
I appreciate you guys taking the time to think about this and help myself, and the others. Thanks again.
- Bob T
steelespike
Good luck,hope it turns out to be something minor.
