Proper battery for Mercruiser 470 I/O motor - Cold Cranking Amps?
kevinstan
Can someone tell me the proper CCA's that I will need for my Mercruiser 470? I cant find anything specific online. Is too much bad? I have seen 845 and 1000 CCA's listed, but is it a good idea to guess and just get one of those? Or does it need to be specific to the engine?
Too much is never bad. You only need about 600 cca. A group 24 would be more than sufficient for a starting battery. However if your going to start adding other loads such as radio, trolling motor, electronics, etc and you only have one battery - get the biggest battery you can fit
H20Rat
To go along with what scott mentioned, I'd even maybe consider a hybrid or deep cycle as a main starting battery for that boat. A 470 doesn't require much to spin over, but if you have a bunch of things you need to run with the key off, the extra reserve capacity can be nice. I'm running a deep cycle on my 4.3l, starts great all the time and I have lots of extra stereo run-time available.
stonyloam
Yeah, I am from the "can't have too much battery school". It depends on your setup. If you have a single battery and only have room for a class 24, then go for a starting battery with the higher CCA rating. If you have room for a larger class 27 battery (may just have to change battery tray or box) then a dual purpose battery may be the ticket, especially if you have accessories.
