proper mixture
plmbr
I have a 1953 Johnson Sea Horse 5 HP and have been using the same gas and mixture [50:to1] as I use in my 1990 9.9 . My question is. Is this enough oil in the mixture for the 5 as the old mixture was 1qt. to five imp. gallons back in the day. Thanks ...Plmbr
rjezuit
Re: proper mixture
I believe 50:1 is too lean. 16:1 or 24:1 is correct. Rick
rolmops
Re: proper mixture
Your little engine does not have needle bearings and because of that it needs a lot of lubrication to keep the bushings well oiled.Stick to 1:16 or 1:24 and you will enjoy your engine for another 50 years.
JB
Re: proper mixture
24:1 is a safe mix using TC-W3 outboard oil. The 16:1 mix was using SAE 30W motor oil.
