Re: Proper procedure to prime an oil pump please?
Follow steves advice, but you should pour a little oil in the pump before putting it on, most of it will run out though, but you will at least be sure you do not have a dry pump to start with. Most are coated with grease, but some come dry. Dry pumps will not prime themselves.
