proper prop for 73 evinrude 50hp
BIGcarpy50
just picked up a 50hp evinrude model # 50373 it came with a composite 4 blade prop and i want to upgrade. what should i look for in terms or pitch and what not . I'm just going to be fishing mostly with the boat.
rndn
Re: proper prop for 73 evinrude 50hp
I live about 25 miles south of Rochester.
Before a prop can be suggested you need to tell us how the current setup is performing with the dimensions of the current prop. Needed are current rpm's at wide open throttle(WOT), top speed, pitch of current prop.
BIGcarpy50
current prop is 4x13.5x15.....i am new to bigger motors i have lived with 9.9s all my life so how would i know the rms at wot....
Titanium48
^^^ I'm guessing you don't have a tachometer. You will need to install one if you want to do any propeller optimization.
rndn
Either see if your marina will lend you one or pick up a Tiny Tach.
BIGcarpy50
how would i install one. it says operating range is between 5000 and 6000 rpm on the serial plate
steelespike
The tiny tach has a web site and is easy to install and will work on any 2 cylinder motor without regard to stator poles.Just be sure to explain to them what you have.
