Proper prop??
I have a 19' God free hurricane deck boat With A1419 pitch 3 blade prop Wanting a better whole shot and smoother plane Wondering If a 4 blade prop would do me Justice
jimmbo
Welcome to iboats
What engine does the Boat have?
What is the WOT Rpm range for that engine?
What WOT Rpms is it attaining with the current Prop.
3.7 l mercruiser
4200-4600 WOT is spec
I'm running 3600 ot of the hole with a big skier
Preforms well empty
jimmbo
Definitely need to go to a Lower Pitch, of course, I am assuming the engine is in good Mechanical shape, in tune, and able to make its rated HP
QBhoy
3.7 l mercruiser
Preforms well empty
What are you running wide open throttle though and well trimmed… without pulling a skier.
jimmbo
4200, still on the Low Side, drop 2 inches in Pitch on the 3 blade, and you will notice much better hole shot, and maybe another mph
jimmbo
Yes, you will probably lose a couple more hundred Rpm
Scott06
jimbo is steering you straight need to drop pitch
17” three balde should get you to about 4600 rpm
if 4 blade would go 16 or 15”
are u currently using aluminum ?if you want to pull skiiers try a michigan vortex 4 blade 16” i used one on my previous boat did wonders for holeshot
