willienelsonjr
- Jun 30, 2007
- 11
I just bought a boat that sat for many years. The engine was tested and repaired before i bought it. the shop replaced the head gasket and transmission pump. runs great once i get it started.
it is hard to start? what is the correct procedure? i have to turn the primer to the manual position to get it to fire up at the start of each use.
Can i run BG44k fuel addative through the fuel system? is it safe? will it help the starting.
thanks in advance.
thanks in advance.
