Proper Trailer Tire Pressure
msd58
I have tandem axle trailer under a 26.5'' boat that weighs 5300 #'s dry (the boat thats is). The tire size is 205 75D 14 load range C. What is right tire pressure?
Thanks
JB
Re: Proper Trailer Tire Pressure
Look on the sidewall for proper pressure. Probably 50psi if they are ST tires. If they aren't, get ST tires.
msd58
I believe they are ST tires
ebry710
Ensign
JB is not kidding. In real small print, the manufactures recommended tire pressure is located on the side of the tire. It is usually looks like a really long sentence with a lot of technical stuff with both psi and kg/m. :)
Silvertip
You don't need a "recommended tire pressure" you need to air up the tires to the pressure stated on the sidewall of the tire. Only at that pressure will the tire safely carry its maximum load. Since the vast majority of trailers are loaded very near their upper limits it is simply nonsense to air the tires to some lesser number. Those charts are provided to simply illustrate what the tire can be loaded to at a given pressure.
tashasdaddy
totally agree with Silvertip. tire pressure is the #1 cause for trailer tire failure.
ebry710
Ensign
I have missed something. Why aren't we looking on the sidewall? All that "gobbly goop" on the sidewall tells tire pressure and tire rating. I understand not knowing it is there, but not reading it would not be my first choice.
msd58
After I clean the dirt off and looked closer it is stamped on tire 50 PSI
JoLin
I don't think it's nonsense. Overinflating tires is no better than underinflating them. I think the owner needs to figure out how much weight the tires are actually carrying relative to their maximum capacity, and then inflate accordingly. It doesn't take all that long to do. After a couple minutes of figuring, I decided that my tires should be inflated to 80% of capacity (40 lbs) rather than the 50 lbs. max pressure stated on the sidewall.
Mark42
You need to check the warranty info for your tires. Many manufacturers specify that the tires must be inflated to the maximum pressure at all times to maintain warranty coverage.
ebry710
Ensign
There are way too many decisions to be made for me to start out thinking a tire manufacturer. If the tires says 50#, I inflate it to 50# and then go fishing. :rolleyes:
Silvertip
JoLin - have you actually weighed your trailer when loaded. Bet you haven't and are only "guessing" at the total load. Guesses are generally on the very light side. Besides, who wants to be bothered weighing the trailer each time it's used, then check the chart, inflate/deflate the tires only to have to repeat the process next time. Aired up tires tow easier, flex less, create less heat and last longer. Car tires are a different story since they need to ride nice, provide traction, and provide turning response as well as interact with the shocks designed for the vehicle dynamics.
Silvertip
Bass & Walleye Boats magazine has a good "trailer tires" article this month. it confirms what we've indicated. It also shows what underinflation does to a tire.
JoLin
Okay, I'll stand corrected.
D
DJ
Guest
Agreed. Trailer tires are a different animal in a different application.
ebry710
Ensign
Agreed, that is why tire manufacturers spent the time and money to "ST" stamp them and not "P" stamp them. If tire manufactures could make one tire to do all they would. A trailer is just a "buck-board" and the tires end up taking a heck of a lot of abuse.
